I'm almost positive that I've found where to plug in the A/C recharger
cans you can buy at autoparts stores but I'm not sure, just clarifying that it is in the front most right section of the engine compartment where there is a thick tube on either sideo f it then the black dust cap on a thinner portion, it appears that the thicker parts are just insulation, so if anyone coudl let me know if this is what i suspect it to be thanks. -Gibs- |
its hard to do it yourself...trust me take it to a trained mechanic and they can do it for you and your a/c will be much colder than if you did it yourself..trust me im a mechanic.. |
| All times are GMT -5. The time now is 12:37 AM. |
