has anyone had this problem with their vehicle, mine is a 2001, took it the dealer when the problem first stated, they could not find any problem, no leaks, pressure test ok, only happens on cold start up.
check the level float in the reserve tank. when it does go on.go under the hood and hit it(the tank)a few good wacks. see if the light goes out. sometimes they stick Edited by: LM_ServiceAdv
well I never got a chance to give that a shot, I took the car for some service the other day, change plugs, fuel filter and Emmision test, the light has never come back on since, and I know it's not burnt out because when I start the engine hot or cold the light does come on for a moment, but that's normal. Still runs just fine.
| All times are GMT -5. The time now is 05:32 AM. |
