Boat in “fail safe” mode
started throwing alarm constant beeeeeeeeep. Unplugged overheat alarm and had no change, unplugged oil tank and alarm went off. Alarm is active with key on engine off. Read on many forums that if I unplug tank then the engine will run normal. So I test ran boat but engine is still in “derate mode” funny thing is the boat has no control module. What should I check? Thanks guys
