I have a 2002 Sable which has started to make a squeaking noise near the throttle linkage. I sounds like a belt squeak but obviously isn't at its location. I have no engine light and therefore no codes. Any Ideas of what could be making the noise? It seems to go away during acceleration, however does not change whether it is in gear or not. Any help would be appreciated. Thanks in Advance. |
are you certain that it isnt a vacuum leak?
its the cam syncronizer going bad its in the place where the distributor would be its driven by the oil pump and if it locks up it wiil stop the oil pump need i say more hope this helps
| All times are GMT -5. The time now is 04:01 AM. |
