False Alarm trips '98 Tracer
Experiencing false trips on the factory installed alarm/alert when the car is off. It will just randomly go on, horn sounding and lights flashing. The only way I have determined to stop it is to disconnect the battery, which seems to temporarily reset the system. Any help???
Thanks! |
if the battery is having low voltage issues, it could cause this. the alarms usually sound off when the battery is first connected, requiring a signal from the remote. also, if the battery terminals are not tight, it could cause intermittent voltage drops too.
False Alarm trips 98 Tracer
i have the same car, same problem sometimes when locking it chirps but more often then not. just wondering if there is a way to arm or not?
| All times are GMT -5. The time now is 06:50 AM. |
