FRONT AWD PROBLEM
Old 01-05-2009, 11:17 AM
I recently had to replace the front gears and housing on my 02 Mountaineer , it is awd . The problem I am having now is, after I drive for an hour or more it has blown the fliud out of the front gear housing that I had replaced. I hope this makes sense to someone! Has anyone else experienced front end problems on the awd of their Mountaineer?[img]smileys/smiley5.gif[/img]
Old 01-05-2009, 04:23 PM
something''s not put together properly. is there a leaky gasket? a fill hole not plugged?
Old 01-05-2009, 05:29 PM
If the housing is not cracked, it sounds like a gasket issue. There are many on the front differential.
I have the counterpart, Explorer, and had the entire driveline rebuilt. During this process, the shop discovered that one of the front axles was not installed properly, the seal was not evenly inserted.
This never caused an issue, till the ControlTrac (automatic AWD) kicked in. Then I suddenly had a fluid leak, due to the force applied to the front differential.
Greetings!
Old 01-12-2009, 11:30 AM
After further evaluation it appears that the front end is building up pressure and then it blows the fluid out of the vent hole on the housing . Anyone have any idea what could be causing this ?
joelamp
08-09-2007 02:29 PM
vesman
06-13-2007 09:24 AM
Hotshot
04-12-2006 02:21 AM
stumped
04-21-2005 03:02 PM
rfurr
02-06-2005 08:32 PM
Quick Reply: FRONT AWD PROBLEM
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
