-   -   Head Gaskets (https://www.mercuryforum.com/forum/general-tech-help-12/head-gaskets-4980/)
pirox_2012 Aug 11, 2010 08:43 PM
Head Gaskets
On a '97 Grand Marquis does the 4.6 have history of head gasket problems? If so, does it cause bottom-end problems if you only re-build the top half?
87_Crown_Vic Aug 12, 2010 08:47 PM
i think the bigger issue with your car is the intake... Ford had a recall on them since they were all plastic... the replaced versions had an aluminum crossover at the front instead of the plastic that cracked
