Help
I was driving my 92 grand Marquis and it just stopped on me changed alternator out still won't crank
If your Merc stopped running due to a dead alternator, the BATTERY has been completely discharged as well.
You will need a LONG, SLOW charge on your battery, using a 6-to-10 AMP automatic charger to avoid battery plate damage. When replacing an alternator, ALWAYS DISCONNECT THE NEGATIVE BATTERY TERMINAL FIRST, and DO NOT reconnect the Negative terminal until ALL electrical work has been completed. |
Originally Posted by 95 MERC
(Post 20537)
You will need a LONG, SLOW charge on your battery, using a 6-to-10 AMP automatic charger to avoid battery plate damage. When replacing an alternator, ALWAYS DISCONNECT THE NEGATIVE BATTERY TERMINAL FIRST, and DO NOT reconnect the Negative terminal until ALL electrical work has been completed. it makes a click sound when I turn key over |
The "click" sound indicates that no power is reaching the starter.
Make sure battery has the proper water level and that it is fully charged. Check for loose connections at the battery terminals and at the starter. If the battery is charged up and all terminals are tight, the starter should crank the engine. If the starter doesn't crank the engine, you can remove it and have it tested at most auto parts places -- AutoZone, O'Reilly's, NAPA, etc. |
| All times are GMT -5. The time now is 07:47 AM. |
