-   -   HELP DROVE THRU FLOOD (https://www.mercuryforum.com/forum/general-tech-help-12/help-drove-thru-flood-1987/)
deddhedd Sep 7, 2008 07:44 AM
8pm
drove thru 1 ft of water notl ong at all, got thru, stalled.
pushed car to safe area.
tried to start, click click,
waited
turned key heard a spinning sound (starter??)
waited 1 hour
tried
car was trying to turn over, almost there,
i got too anzious, had key turning for over 30 seconds
then water flew out of the exhaust pipe, oair filter soaked,
now
no start
click
click
even with full battery
did i kill something???
car is in a lot in Newark NJ 34 miles away
got home 3:30am
jason sereiko Sep 8, 2008 11:40 AM
you could of bent a push rod.
you need to see if you can turn the motor over. the best way is to remove all the spark plugs because this frees up the compression, then with a socket on the crand, see if it turns. it not it could meann the motor has something internal wrong. If so your insurance will cover it since it was an accident with the water.
I would call your insurance company. my buddy did the same thing and bent a push rod, the insurance company wrote it off and gave him a check for the amount the car was worth.
