ignition key lock cylinder
Old 09-14-2008, 08:34 PM
Key does not go into ignition smoothly. Have lubricated does not help. I want to remove the cylinder but can not get it to release. I have removed the plastic cover from the column. I am told with Fords you can insert the key turn it half way and push a release button through an access hole. I can not locate a release or remove the bottom plate to gain access to the cylinder. There is a triangular shaped plate at the bottom of the casting but I can not get it off. Does anyone have experiance with this. Car was built as a joint venture between Mazda and Ford called autoalliance. <BR itxtvisited="1">
jwcaylor
09-09-2008 10:09 PM
Chanel63
06-11-2008 01:25 PM
forkliftrman
03-04-2008 10:12 AM
pkucan
01-03-2007 08:51 PM
SableCat
09-10-2005 08:12 PM
Quick Reply: ignition key lock cylinder
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
