-   -   installing keyless entry, please help!!!!! (https://www.mercuryforum.com/forum/general-tech-help-12/installing-keyless-entry-please-help-5749/)
TheMercuryCalledBeans Aug 19, 2011 11:22 PM
i have a 1994 mercury Grand Marquis GS bought a keyless entry system, ok?and im reading the directions, im following the directions to a t, but when it got to the 12v constant wire part, i came to a huge problem! on the ignition switch harness, their are like... 4 yellow wires, all solid yellow, the site (bulldogsecurity.com) has a helping thing that shows what the color of the wire is and its location. but all it says is a yellow wire on the ignition switch harness.... not which one.... are thay all 12 volt constant? or am i looking at the wrong thing? http://www.google.com/imgres?q=1994+...1t:429,r:7,s:0 this is what it looks like, kinda. its the closest thing i could find on google, and i dont have a camera any more. also, where is the starter wire in this? the diagram said a white and pink wire, but i only found a white and red wire. is that the wire? please help! im stuck! :eek: :eek: :eek: :eek:
TheMercuryCalledBeans Aug 20, 2011 01:53 PM
never mind, i got it to work, turns out all aof the yellow wires are hot
jakesulivan Sep 12, 2011 12:28 PM
How did you do that? Is it easy because once I also faced same thing but all efforts I have to go the service station.
