Keyless Entry code location 2006 GM
I purchased a 2006 Mercury Grand marquis LS about 4 months ago and have been trying to find the Keyless entry code. It is NOT on the unit in the Drivers door or anywhere else that I can find. It is nor on any doors or jams, on the fuse book under the hood or as near as I can tell under the dash. Where else can I look or is the only choice the dealer to read it out of the computer???
Key Code Location
Open the trunk lid.
Look at the top side of the trunk hinge on the driver's side. The code should be on a white sticker with black numerals. Once you have the factory code, you can add your own private 5-digit number. The original number will still work, too. |
Looked on truck hinge- not there
I was hoping you had the answer - but no luck. It was not on the trunk hinge. Thanks for the response however Now where???.
Sorry, Bill --
Mine was on the trunk hinge. I don't know where else to look. Maybe a call to a Ford/Lincoln dealer would help. Good luck !! |
I believe after 2005 they stopped printing them on the vehicle, your only hope is to take your driver side door panel off and it will be printed on lock control module i think its called.
Ton of youtube videos on this topic. |
Keyless Entry Code
Sorry I couldn't help ya, Bill -- Thanks for the update !
| All times are GMT -5. The time now is 07:39 AM. |
