Mercury Electrical Question
Old 10-13-2008, 10:48 PM
My Car: 2000 Mercury Grand Marquis, 81,000 miles. I have had the car for three years. About two months ago I noticed the following: The idle was faultering. Also, when using the turn signals, the digital temperature indicator light would dim and brighten with each flash of the signal. I had the alternator and battery tested. The battery was bad. I replaced the battery. The Idle has returned to normal. However, the temp. indicator light still fluctuates in brightness when the turn signals are on. The mechanic said it was because of normal drain of the amperage
from the battery. Do I have a ground problem? [img]smileys/smiley25.gif[/img]
Old 11-10-2008, 03:08 AM
You could check the part # on your alt. and make sure it is the correct one for your car. If the car is loaded and it has a lower amp. alt from a base model I can see this happening. But if the batt. and charging system are in check than I would leave it. But if it really bothers you, check into getting a higher output alt. and or bigger batt. Did this prob occur right before you had the batt. changed and the prob persisted? If so they may have skimped n the battery.
georg15232
10-18-2008 09:18 PM
benzclassic
08-16-2008 01:15 AM
99MGM
06-13-2008 11:50 AM
klzeprobe83
01-03-2008 11:10 AM
NitrousInfected
06-12-2006 06:25 PM
Quick Reply: Mercury Electrical Question
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
