Please read
Old Feb 23, 2009 | 03:09 AM
Mint97's Avatar
Hello my name is Josh
I have a 1997 MGM i just got 3 day of driving the power lock stoped working i looked at the cicuit braker tested good also tested relay also tested good thes are the things that stoped also
power locks
power trunk
window auto down
any help would be great that you all vary much
Josh
Old Feb 23, 2009 | 12:23 PM
check the wire harnesses in the door to make sure they''re still fully connected. it almost sounds like something came loose. You may have to trace it to the ground under the dash there on the driver side and make sure the ground lines that bolt to the car are still tight.
There''s also a window controller that takes care of the auto-down function and may also relay the rest. I''ll check in my Chilton''s later to see what all it does. This module may have died.
Old Feb 23, 2009 | 02:22 PM
Mint97's Avatar
today i am goin to chech fuses and for power at the swich thanks for the help hope we can get this fixed
administrator
Dec 10, 2014 11:40 AM
tony
Apr 13, 2007 11:54 PM
Sarge148
Mar 6, 2006 08:49 PM
administrator
Nov 28, 2005 06:13 PM
babynhoney48
Jul 16, 2005 09:49 AM
