-   -   Sable code P1409 HELP!! (https://www.mercuryforum.com/forum/general-tech-help-12/sable-code-p1409-help-1608/)
saeric Feb 25, 2008 02:45 PM
<DIV class=uwePostText>My car originally failed emissions testing because it threw a code for the bank 2 oxygen sensors. I replaced the sensors, cleared the codes, and tested to make sure no other codes were thrown. It showed clear of any codes and I had no check engine light. When I went back to the DMV andthey plugged in, up popped code P1409! Now the car has the engine light on again, and I have no clue what the problem is or what caused this new code to pop up out of the blue. Does the EVR actually need replacement, or did the new O2 sensors cause this? Any ideas??
</DIV>
