-   -   Single action hydraulic spring compressor (https://www.mercuryforum.com/forum/general-tech-help-12/single-action-hydraulic-spring-compressor-3896/)
slymer Nov 15, 2009 01:40 PM
ya know those single action spring compressors for coil springs...
http://www.jcwhitney.com/jcwhitney/s...26859_SW_1.gif
Anyone know of a hydraulic version?
all the spring compressors out there that's I've found so far are for struts or with very little clearance for a side grabber type. with the fat control arms on the old MGM, you have no chance of using those. The screw down version does work. but takes an hour just for one spring with a breakover bar. Apparently I'm too much of a wuss to be able to do that while laying under the car with it as high as it will get off the ground on jack stands. I poop out after about 40 minutes of cranking and the springs still aren't quite compressed enough to help with replacing the control arm bushings.
slymer Nov 24, 2009 09:58 AM
Thought so... Looks like I'll have to find a 2-5 ton hydraulic ram (pull type) and cannibalize a single action spring compressor to create my own.
dimekind73 Dec 2, 2009 05:19 AM
Thanks Dan, I appreciate it. Ill give you a ring for the 3/4 heims for the shackles...Are your spring plates customable? Or one size fits all?
slymer Dec 2, 2009 08:20 PM
wrong thread maybe?
D.Aroke Dec 4, 2009 11:39 AM
I'll probably just buy them. I'm guessing you are using the pro tools 105 dies?
Aftedia09 Dec 23, 2009 06:29 AM
im after a bush thats 40mm wide with an 18mm shackle pin hole... does anyone know if a bush is made at that size... if not whats the closest size with an 18mm hole
they are for a 50mm wide spring
