01 Grand Marquis LCM schismatic
Old Aug 1, 2021 | 08:40 AM
Houdini379's Avatar
Default 01 Grand Marquis LCM schismatic
I have a 2001 Grand Marquis and I'm looking for a schismatic for the LCM. I have a rapid flasher problem and before I spend $200+ on a replacement I'd like to open it up and look for loose solder joints or bad components. The problem seems to not happen when the headlights are on. Before you ask, all the lights are working and i checked all the connections I could get to. Any help would be appreciated.
Old Aug 1, 2021 | 09:09 AM
Are you talking about a "HYPER-FLASH" problem !??
If so, what kind of bulbs are you using !??
Switching from OEM bulbs to LEDs often causes hyper-flashing -- and resistors must be added to each bulb to prevent the hyper-flashing.
I got my Resistor Kits from Amazon.com -- a few minutes to install each resistor solved the problem immediately.
1995 Grand Marquis Restoration - Mercury Forum - Mercury Enthusiasts Forums
Old Aug 1, 2021 | 10:15 AM
Houdini379's Avatar
It still has regular bulbs in it. Before I switch to LEDs I need to get this problem fixed.
burlap
Jan 15, 2017 04:14 AM
chuckjones
Apr 26, 2016 10:37 AM
newshutr
Oct 23, 2011 01:18 PM
rlhate04
Jul 9, 2011 08:07 PM
ddgreene
May 7, 2010 08:56 PM
