throttle position sensor adjustment
Old 12-28-2012, 09:05 AM
2002merc's Avatar
Default throttle position sensor adjustment
is there a way to adjust the throttle postion sensor on a 2002 marquis 4.6l and if so how ?
Old 12-28-2012, 11:01 PM
sbills55's Avatar
I don't think there is any adjustment on the throttle sensor.. I would clean the throttle plate first and make sure it opens and closes freely.. if that is your problem.... I am not sure if this helps I need more input...
Old 12-29-2012, 05:26 AM
2002merc's Avatar
Replaced old one cause the check engine light came on with that code. Drove around a bit and same code came back with new sensor.
Old 12-29-2012, 06:24 AM
sbills55's Avatar
Is the throttle clean? Open and close ok? Also What code do you have... are all vaccum lines ok? how does engine run? Throttle position sensor is an R&R only no adjustment that I know... something else is wrong let me know
Old 12-31-2012, 03:31 PM
charle123's Avatar
the tps is non adjustible you may have a bad new tps compare measurements with the old to tps to the new one
Old 01-01-2013, 01:04 AM
EddieE's Avatar
Non-adjustable,
Linkage binding or sticking?, free movement of throttle plate, returns to closed throttle?
TPS properly tightened down?
Check both sides of the plug for damaged/loose pins, pushed out pins/connections?
Check that you have voltage between VREF and SIG RTN at the TP harness connector?
Old 01-01-2013, 07:03 AM
2002merc's Avatar
I checked all the voltages and they were good. Do I got another sensor and now it works fine no light no sputtering. Gues it was just a defective sensor. Thank you everybody for your help.
salvatore
10-15-2018 05:23 AM
bmcs
02-05-2015 11:46 PM
2003Mercury
07-02-2009 08:07 AM
Quick Reply: throttle position sensor adjustment
