04 Headlamp diagnosis
04 CV/MGM headlamp failure is often times blamed on a faulty LCM relay. As a newbee to this forum, I need help from you avid, experienced owner’s. What items besides the fuses in the dash fuse panel that check OK, can I check to eliminate before concluding my LCM is at fault. I don’t have the device required to run the Ford tests for DTCS at the LCM. Many thanks for your advice.PLEASE help soon - can't drive car at night. ~Dick :confused: |
You can have your LCM rebuilt bu vendors on eBay for about $100. If you can solder, I'll send you a link on how to replace the LCM relays yourself. Good Luck, Bill
billccm: I would appreciate you're sending that link on replacing the LCM relays myself. I hope it shows how to identify the headlamp relays, as I understand there are 4 relays in the LCM. If you wish, you can send link to my desktop: rlhate@ptd.net. Many Thanks, Dick
i have the same problem and i did a lot of research its the lcm what you may want to do when they go out tap on the lcm and if your lights come on like mind did that will be it thats a big problem its very easy to replace its under dash on the right side of steering colum its about 5inch long 5 inch wide a new one is like 400 i got a rebuilt for $125.00
hope this helps Regards, travler |
| All times are GMT -5. The time now is 05:16 AM. |
