1985 Mercury Marquis Brougham
Old Dec 29, 2011 | 01:16 PM
blaiscaz's Avatar
Default 1985 Mercury Marquis Brougham
I do know this is in the Grand Marquis section, but I cannot find anywhere else to help me with my car's problem.
Since October, my car has developed a problem in starting. It literally does not warm itself up and has no cold start. I have replaced both the idle control motor and coolant temperature sensor. The engine is a 3.8L V6 and it is CFI. Orginally, the idle control motor did fix a problem with the car always idling too high, then the cold start issue started about a week after I put in the new motor.
I have taken note that the vacuum to the motor on the air intake to direct the vent down to the headers is now nonexistant. I was under the impression the the computer thought the engine was warm from false readings of the coolant sensor, but that is not the case. I am now thinking that it could be the air temp sensor? Anyone got any suggestions or info on Ford 80's fuel injection cold starts? Thanks.
Old Jan 18, 2012 | 12:07 AM
cold starting issues can be caused from needing plugs, wires, cap and rotor kit and even fuel filter restricting fuel from engine like a friends car is doing...
sirwalters
Oct 25, 2013 03:14 PM
lawinchaos
Dec 14, 2011 09:48 PM
trogg
May 3, 2009 08:13 PM
Skip
Mar 11, 2009 12:33 PM
phiwgf
Aug 25, 2007 12:03 PM
