1992 Marquis NO HEAT Problem
Old Dec 24, 2010 | 05:13 PM
Mil1ion's Avatar
Default 1992 Marquis NO HEAT Problem
When everything on the ATC system except for NO HEAT to Interior, the problem is usually the Electronic Blend Door Actuator
Notice on this CV that the parts and placement are pretty well the same.
http://www.crownvic.net/ubbthreads/u...484483&fpart=2
Ford Numbering !
Due Ford's endless efforts to keep people in the dark on Ford PART Numbering vs ENGINEERING Number that are stamped on Ford parts please know that Ford is changing coding numbers
This is where the XW7Z19E616BA replaces the Original Ford Part # of
F0VH19D961AA
then the supercede # of F8VZ19E616BA
to the NEW supercede Number of XW7Z19E616BA
Please be aware the pricing of this part today is dependent on the Part Number Used
The Original OBSOLETE part can be had for $19.00
while the NEW Motorcraft Part sells for between $33.00 & $80.00
I hope this helps people here with this curious issue.
Further I will be posting the Testing procedure of this part so you can tell if it is broken/faulty or not before buying.
EDIT: as promised
Click multiple time to get close up.
iceman536
Nov 26, 2010 10:17 PM
sledfreak700
Jan 20, 2010 12:08 PM
MorePower
Aug 20, 2009 04:04 PM
dwonzer12
May 4, 2009 10:21 AM
wern
Jun 25, 2007 10:31 AM
