1992 Marquis NO HEAT Problem
When everything on the ATC system except for NO HEAT to Interior, the problem is usually the Electronic Blend Door Actuator
Notice on this CV that the parts and placement are pretty well the same. http://www.crownvic.net/ubbthreads/u...484483&fpart=2 Ford Numbering ! Due Ford's endless efforts to keep people in the dark on Ford PART Numbering vs ENGINEERING Number that are stamped on Ford parts please know that Ford is changing coding numbers This is where the XW7Z19E616BA replaces the Original Ford Part # of F0VH19D961AA then the supercede # of F8VZ19E616BA to the NEW supercede Number of XW7Z19E616BA Please be aware the pricing of this part today is dependent on the Part Number Used The Original OBSOLETE part can be had for $19.00 while the NEW Motorcraft Part sells for between $33.00 & $80.00 I hope this helps people here with this curious issue. Further I will be posting the Testing procedure of this part so you can tell if it is broken/faulty or not before buying. EDIT: as promised Click multiple time to get close up. http://inlinethumb37.webshots.com/45...600x600Q85.jpg |
| All times are GMT -5. The time now is 05:36 AM. |
