1992 MGM Question
Old Nov 21, 2007 | 09:15 PM
92mercmadman's Avatar
I have the keyless entry module in the truck and i checked my door panel and the wiring is there. Now im not a fan of cutting a hole in my door, so does anyone know any cheaper ways of using that module or am i just outta luck and full of tears. LOL
-cheers
Old Nov 21, 2007 | 09:25 PM
20marquis07's Avatar
to my knowledge, the only way to get the module attached is to cut the proverbial hole in the driver's door. I agree with you I'm not much on cutting sheet metal for those cars, and you have to be programmed to the car itself before it works.
On 98+ models I know you have to connect the service dept's laptop up, plug in the VIN and let it "find" the door/key code same way it programs your keyless door fobs.
If the car wasn't originally equipped with keyless door pad, not sure even if it were connected that the computer could find it. May be a dealer question - unless someone else out there is more familiar with connecting these after the fact.
Old Nov 22, 2007 | 12:17 AM
92Mercury's Avatar
Actually, there's no need to cut any hole into your door.
Just to clarify (you didn't state exactly what you have and what you don't), it seems you don't even have the keypad on the door?
I already answered your comment about that in another post, use the search function and you will see.
Well, the keypad on the door functions the same way as the remote transmitter which is found on newer models. I personally like them better, you can lock and unlock your vehicle with the push of a button, instead of punching in 5 numbers. Believe me, when it's raining, it makes a difference.
So what you can do it get the module for the remote transmitter. You don't even have to get the original one, any aftermarket will do.
And if yougo with i.e. Bulldog (http://www.bulldogsecurity.com/), you can not only add alarm, remote start or other functions, they even have a prewired harness which plugs into your original harness.
So it's kind of plug and play. JC Whitney (www.jcwhitney.com) has several options.
The harness, i.e. from Bulldog for all MGM's '90 to '03 (are all the same) is called FD-1 and looks like this:
[img]uploads/92Mercury/FD-1.JPG[/img]
Greetings!
MorePower
Aug 20, 2009 04:04 PM
MItoplock
Aug 8, 2008 10:39 PM
jessepatty
Jun 28, 2008 10:39 PM
99MGM
Jun 13, 2008 11:50 AM
klzeprobe83
Jan 3, 2008 11:10 AM
