1993 Grand Marquis Torsion Bar Bolts
Hi, new to the forum...
Has anyone removed the torsion bar bolts (4 of them) that connect the 2 center brackets to the underside of the frame? I tried to remove mine and stripped 3 of the 4. The only good news is that I did replace the broken torsion bar end rod where it ties into the right A-arm/axle by the disc brake. Now I have to fix them and it doesn't look like it's going to be easy: there's no good access into the frame where the bolt heads are. Do I have to cut off the bolts with a sawzall and replace them that way? Any help would be greatly appreciated. Thanks. -Randall |
| All times are GMT -5. The time now is 06:37 AM. |
