-   -   1993 Grand Marquis won't start (https://www.mercuryforum.com/forum/grand-marquis-14/1993-grand-marquis-wont-start-4968/)
hanyou_kimura Aug 7, 2010 09:10 PM
Well this is inconvenient. Went to move the GM so I could get my car out of the garage and it wouldn't start. Lights come on, dash lights come on, but doesn't turn over. No clicks or anything. It was fun earlier today.
What are some possible causes? Loose connection, relay or fuse?
87_Crown_Vic Aug 12, 2010 07:10 PM
i would check the fuses under the hood ... have you tried starting in neutral? if it starts the neutral switch might have died
danati Aug 27, 2010 12:50 PM
have you checked the ignition switch.
adam696 Sep 1, 2010 12:44 AM
Ya there can be a loose connection or fuse problem.Do check the car and if the problem is not solved then do tell us.
Lowkey Sep 10, 2010 01:59 PM
Take the battery and have it load tested. May be faulty battery. Needs a lot of volts to crank.
crazyrog17 Sep 15, 2010 08:26 AM
the lights would go out if it sucked enough volts not to make a click though.
bad fuse, first place to look. my car blew a megafuse for the starter one day inexplicably. replaced it and it's never happened since.
