1994 Marquis/1995 Crown Vic Fenders
Hi - first time posting. I would like to know if the fenders off of a 1995 Crown Victoria would fit a 1994 Mercury Grand Marquis. Found two in a junk yard and I need both of them if they fit. Thanks.
No the trim is different between the ford & merc, particularly at the parking-side lights.
Now if you wanted to put the whole front end on, including the trim, & grille, that might work, although I don't know for sure, but the panthers didn't change much in those years. Sounds like you may have wrecked the car. Have you priced out another car, as there are many panther cars out there. Oh you may want to check if the bumpers are different. I know the MGM has fog lights(or openings for them), and the CV doesn't. Lets see now, if you put a Ford front end on the Mercury, would that be a Crown-Marquis, or a Grand Victoria? |
Okay thanks. I didn't wreck it - just extreme rust but only on the front fenders. It's rough up here in the North East on cars and this one has 192K miles on it.
I use to live in Connecticut, so I know about the steel eaters they put on the roads in the winter.
I have been getting error codes saying that its running rich. Usually I'd adjust the timing, check the distributor cap and rotor.
