I just changed the thermostat and the antifreeze on my 95 G.Marquis.The hose on the upper side of the radioator is not getting enough antifreeze therefore the temprature is always low.What i understand is there is air in the system but i don't know how to realese it.Can any body help me with this. Thank You[img]smileys/smiley1.gif[/img] |
Get The Newer-Type Thermostat !
Replace your thermostat with a MOTORCRAFT # RT1234.
The Motorcarft RT1234 replaces the earlier model 'stats as a more accurate and efficient design. Also, replace the old cap on the coolant reservoir, as it MUST be sealing the system so that the coolant level will MAINTAIN ITSELF when the proper thermostat and coolant reservoir cap are installed. |
| All times are GMT -5. The time now is 05:07 AM. |
