1995 marquis ls...disable air suspension alarm
Old 08-29-2010, 08:01 PM
baginz's Avatar
Default 1995 marquis ls...disable air suspension alarm
I removed the air bags on my 1995 Grand Marquis and installed coil springs and shocks.Even though I turned air suspension off,the air suspension alarm comes on after a short distance and stays on.How do I disable this alarm.......-: Thank You
Old 09-10-2010, 01:04 AM
carlinjohn's Avatar
I would suggest you to go through the owner's manual.there it will be given how to do it.
Old 09-10-2010, 01:39 PM
question for ya... did you unplug the fuses that run the air ride? i know there is one under the hood and iirc a relay also
Bulldozer's Avatar
Default Air Suspension
Have you tried contacting;
http://www.strutmasters.com
I think they would know how you do it, as they sell the coil spring kits.
I just bought a 2009 MGM which was a rental & I was surprised to see that it came with coil springs already. Seeing how you have now driven the car with both, was there a difference in how it rides and handles?
Old 09-11-2010, 11:42 AM
baginz's Avatar
Thank you all.....removing irc/relay resolved the issue.
Old 04-12-2018, 07:20 PM
Joe308's Avatar
How does the car sit and handle with the conversion kit? My car has the hpp pkg and I just put new kyb shocks all around right before my pump failed so didn't want to remove the air suspension, plus my air bags are still good at 72k miles.
BilalMGM
05-21-2012 09:14 PM
couquis
07-04-2011 09:26 PM
_Brian_
06-30-2011 02:53 PM
mohamsghl
09-11-2010 05:05 PM
Devil Boy
08-17-2009 04:18 PM
Quick Reply: 1995 marquis ls...disable air suspension alarm
