1995 Grand Marquis Restoration
18 Attachment(s)
1995 Grand Marquis GS Restoration.
4.6 Liter Engine is basically stock, with some performance upgrades. Items marked with "#" are/were available for purchase at Amazon.com. (EXCEPT spark plugs. DO NOT buy spark plugs from Amazon.com !) Intake Air Box Snorkel removed - cool air is ducted from forward of the engine compartment. # Pennzoil Ultra Platinum Synthetic Oil - 5-W-20 # Bosch #3410 Premium Oil Filter # FILTERMAG #SS365PR Magnet Kit # FUMOTO #106 Crankcase Drain Valve # K&N *33-2272 Re-usable Air Filter -- for TRIPS ONLY ! # FRAM TGA 5056 Tough Guard Air Filter -- for local driving. # Bosch *69128 Electric Fuel Pump. # Bosch *68015 In-Tank Fuel Filter # Motorcraft *FG-1060 In-Line Fuel Filter # Mallory *4213 Adjustable Fuel Pressure Regulator -- 35 psi. @ 750 rpm, hot idle. # Bosch *4809 Series 3 - 19 lb. Fuel Injectors. # Motorcraft DG-530 Ignition Coils # Bosch *09725 Mag-Core Ignition Wires. # Bosch *9605 Double-Iridium Spark Plugs, gapped at .054". # Motorcraft *PW357 Water Pump. # TYC Aluminum Radiator # FEL-PRO *MS98007T1 Intake Manifold Gasket # Motorcraft *YB541 Fan Clutch. # Bosch *15717 Oxygen Sensors.(4) # Bosch *SR7533N New Starter. # Bosch *AL7537N New 130-Amp Alternator. # Gates *K060980RPM - RPM Series Serpentine Belt. # Gates *38386 DriveAlign Belt Tensioner. # Gates *38006 DriveAlign Belt Tensioner Pulley # Gates *38006 DriveAlign Idler Pulley # Motorcraft *KM2973 Upper Radiator Hose. # Motorcraft *KM2969 Lower Radiator Hose Assembly. # Dorman *624-107 Electric Fan Assembly # Motorcraft *YCC166 Air Conditioning Compressor # Four Seasons *38904 Severe Service Orifice Tube # Behr *351214031 PAO A/C Compressor Oil # WAI Windshield Wiper Motor. # Dorman Windshield Wiper Arms. # Bosch ICON Wiper Blades. # Dual Exhaust - Walker *40383 H-pipe. # MagnaFlow *18134 - 2" x 3.5" x 21" Glasspacks. # Walker Tail Pipes - *46761(right side); *46789 (left side) # Superior *28-6201 2 1/2" x 6" Stainless Steel, Slant-cut Exhaust Tips # B&M *70268 13,000 lb. Transmission Cooler. # B&M *40264 Transmission Shift Improver Kit. # B&M *80250 Transmission Drain Plug. # MOOG Driveshaft U-Joints. # XPERT Performance Cast Aluminum Differential Girdle. # LubeLocker *LLR-F880 Re-Usable Differential Gasket. # Royal Purple 75-W-90 Gear Oil. (80 ounces) # Energy Suspension *4.3150G Urethane Control Arm Bushings (front, upper & lower) # MOOG Greasable Ball Joints, Tie Rods, Idler Arm. (front) # MOOG *K8853 Greaseable End Links (front). # Motorcraft *HUB3 Wheel Bearing Hubs (front) # ADDCO 1 1/4th" Front Anti-Sway Bar, with Energy Suspension Greasable Urethane Bushings. # ADDCO 1" Rear Anti-Sway Bar, Urethane Bushings. # Energy Suspension End Links with Urethane Bushings (rear). NAPA Eclipse Brake Calipers (front & rear). # ACDelco POLICE Drilled & Slotted Brake Rotors (front & rear). # Motorcraft POLICE Brake Pads - BRSD678 (front) & BR107B (rear). # Raybestos Brake Hoses (front & rear) # Bosch EIS-6 - DOT 5.1 - Hi-Temp Brake Fluid. Yokohama Avid Ascend LX Touring Tires - 98T 5 "Italian Lace" 15" alloy wheels (includes spare). # HELLA *980860801 Daytime Running Lights. # iBrightstar LED Flashing Brake Light Bulbs. # Dorman *38445 Door Strikers. # Garmin *66LMT Navigation. Custom headliner by "Hot Rod Interiors", Glendale, AZ. Dual exhaust fitted by "MufflerMasters", Avondale, AZ ** - All parts installed on this restoration are guaranteed to be GLUTEN-FREE. *** - No animals were harmed during this restoration. https://cimg6.ibsrv.net/gimg/www.mer...c09dc30ce5.jpg Mallory Adjustable Fuel Pressure Regulator -- 35 Lbs. @ 750 rpms. - hot idle. https://cimg9.ibsrv.net/gimg/www.mer...d8bb92bac3.jpg '95 MERC Engine Bay https://cimg6.ibsrv.net/gimg/www.mer...2af9a3256a.jpg Sleeping Beauty, Rolling Thunder https://cimg4.ibsrv.net/gimg/www.mer...70be21d0cf.jpg BOSCH Double Iridium Spark Plug '92 - '97 - 4.6 Liter 2v = Bosch #9605 '98 - '10 - 4.6 Liter 2v = Bosch #9606 https://cimg8.ibsrv.net/gimg/www.mer...d3b26f3494.jpg https://cimg0.ibsrv.net/gimg/www.mer...2f53ab1e92.jpg https://cimg8.ibsrv.net/gimg/www.mer...ad48676992.jpg Walker - MagnaFlow Dual Exhaust -- Adds 20-24 Horsepower over Single Exhaust. https://cimg0.ibsrv.net/gimg/www.mer...8651b0bb5e.jpg Sleeping Beauty, Rolling Thunder |
| All times are GMT -5. The time now is 09:50 AM. |
