1995 Grand Marquis Transmission issues
I have a 1995 Marquis and some pretty bad tranny problems..
It slips pretty bad from 2nd to 3rd and 3rd to 4th gear. If you accelerate quickly, it doesn't slip at all. I was wondering if there was any factory defects or maybe some tips that anyone could give me. Also, should I get a rebuild? :confused: |
No defects that I am aware of. Over 200,000 miles on my 96 without issue.
Yes.... Rebuild. |
Do you have any transmission codes showing on a scan? Solenoid malfunctions; valve body problems are common issues. Have you tried changing the fluid - Mercon V, including the converter? There was a TSB about 3-4 shudder and problems suggesting a complete fluid/filter change. Play around with the overdrive switch off see if there is differences.
Originally Posted by EddieE
(Post 17815)
How to replace 95 grand marquis 4R70W transmission control soleniod?, Thanks
