1995 Grand Marquis wheel questions
I'm interested in replacing my OE wheels, but I don't want to put blinged out chrome or any of that on. I'll probably just go with 17 or 18" flat black ones. I'm having a hard time finding the info I need on what rims will fit, tirerack only lists 12 possible styles, mostly muscle car oriented. What do I need to know to order wheels that'll fit? Thanks for any info.
Need to know the diameter of the hole that goes over the axle hub & the lug stud spacing. Measure from the center line of one stud to the c/l of the second stud in line not the very next stud IIRC, then the number of studs on the hub. Tire rack should have that info on their site. You can get a template for pretty cheap that does the spacing measurement for you usually at the wheel stores & they can probably look all that up too.
| All times are GMT -5. The time now is 06:58 AM. |
