dmerc95 |
02-07-2012 02:39 PM |
1995 Marquis coolant leak
I have a 95 marquis LS with 178K. I bought the car about a month ago. After having the car foe about 1 week i noticed the tem guage was running high. I checked the coolant and it was real low. I topped it back off with 50/50 coolant. Ran fine and problem seemed to be that it was just low on coolant. Well 2 weeks later i noticed that coolant is leaking for under the car just before the oil pan. I checked the coolant level and it again was very very low. I dont believe it is the water pump nor thermostat or hoses. Im not sure if its a freeze plug (hope not) or a broken heater hose or bad heater valve. Any suggestions ?
