-   -   1995 marquis egr code (https://www.mercuryforum.com/forum/grand-marquis-14/1995-marquis-egr-code-9829/)
mikeasis Aug 7, 2018 07:55 PM
recently bought a 95 grand marquis after it sat awhile. It has thrown the inefficient flow code twice now. while looking under the hood I noticed a wire off near the fuel rail on the passenger side. I don't see where this goes. I assume it is an option the car didn't come with. I also noticed while looking for the egr valve what looks like an open port. like the upper intake didn't match or something. I included pics but they are poor as it was getting dark out. the open port just goes under the intake into nothing. But there is a gasket there.
Help on where to start with this appreciated.
pics awaiting approval of a moderator
95 MERC Aug 8, 2018 01:33 PM
The "odd" wire with connector on the passenger's side, near the fuel rail, doesn't connect to anything on the '95 Grand Marquis GS model. I just tuck the<br />wire connector behind the fuel rail so it looks nice and neat.<br />As for the EGR valve issue --<br />Send the exact code # for the "insufficient flow", as there can be different flow problems that are not related to the EGR valve itself.<br />I got an "insufficient flow" code that indicated a problem with the EGR valve, but the EGR valve was never removed or replaced.<br />There was a blockage in the EGR system, but it wasn't in the EGR valve -- the blockage was in a passage on the back side of the throttle body.<br />Early models had a metal-based EGR controller (DPFE sensor) that has been replaced by a tough plastic part, which runs much cooler, with less problems.<br />In order to get at the EGR system parts for removal, it will save a lot of time and troubles by first removing the entire windshield-wiper housing from the vehicle.<br />Then, you will be able to see, reach, and access the parts that bolt onto the back of the throttle body, such as the DPFE sensor.<br />The "open port" that you describe is a puzzlement. I can't find anything like that on my '95 MERC<br />Send some good (daytime, and/or lighted) pictures of the exact area in question, please.<br />My '95 MERC restoration now has 156,500 miles on the clock -- starts immediately, idles smoothly, and accelerates quickly.<br />Fuel mileage = 16 city, 25 highway.<br />I do all my own work -- unless it takes welding, or requires specialty tools that I don't have..<br />I use Motorcraft parts whenever they are available.<br />RockAuto.com has excellent prices..<br />.
mikeasis Aug 8, 2018 03:05 PM
ill get pics and or video if it can be uploaded. I feel better about the harness thing. ill report back when I hook up the scanner and get the exact code and those pics
