1995 marquis ls...disable air suspension alarm
I removed the air bags on my 1995 Grand Marquis and installed coil springs and shocks.Even though I turned air suspension off,the air suspension alarm comes on after a short distance and stays on.How do I disable this alarm.......-: Thank You
I would suggest you to go through the owner's manual.there it will be given how to do it.
question for ya... did you unplug the fuses that run the air ride? i know there is one under the hood and iirc a relay also
Air Suspension
Have you tried contacting;
http://www.strutmasters.com I think they would know how you do it, as they sell the coil spring kits. I just bought a 2009 MGM which was a rental & I was surprised to see that it came with coil springs already. Seeing how you have now driven the car with both, was there a difference in how it rides and handles? |
Thank you all.....removing irc/relay resolved the issue.
How does the car sit and handle with the conversion kit? My car has the hpp pkg and I just put new kyb shocks all around right before my pump failed so didn't want to remove the air suspension, plus my air bags are still good at 72k miles.
| All times are GMT -5. The time now is 05:36 AM. |
