1998 P0420 Code
Old Apr 25, 2013 | 04:17 PM
wohara's Avatar
Question 1998 P0420 Code
My OBD2 code reader is telling me that I have a Catalyst System Efficiency Below Threshold (Bank 1).
Which side is Bank 1? Driver or passenger?
While searching on the internet I found the following:
*Leaded fuel was used where unleaded was called for
*A damaged or failed oxygen sensor (HO2S) Downstream oxygen sensor (HO2S) wiring damaged or connected improperly
*The engine coolant temperature sensor is not working properly
*Damaged or leaking exhaust manifold / catalytic converter / muffler / exhaust pipe
*Retarded spark timing
*The oxygen sensors in front and behind the converter are reporting too similar of readings
*Leaking fuel injector or high fuel pressure
*Cylinder misfire
*Oil contamination
I know for sure my coolant temp sensor is not working but the electric fan turns on and off. Must be a separate temp switch!?
I checked for an exhaust leak by tightening the bolts on the exhaust manifold and found a broken one on the driver side closest to the firewall. On the same side, I also noticed a small oil leak coming from a plugged port on the head just above the exhaust manifold flange. It is dripping right onto the flange.
Looks like I found the Trifecta of problems....if Bank 1 is the Driverside.
Any help would be appreciated
FrugalOne
Nov 29, 2010 06:36 PM
photog3740
Aug 24, 2006 02:08 PM
mama0205
Jul 4, 2006 05:53 PM
mama0205
Jul 1, 2006 12:11 PM
BFGRAVES
Feb 10, 2005 04:37 PM
