1998 P0420 Code
My OBD2 code reader is telling me that I have a Catalyst System Efficiency Below Threshold (Bank 1).
Which side is Bank 1? Driver or passenger? While searching on the internet I found the following: *Leaded fuel was used where unleaded was called for *A damaged or failed oxygen sensor (HO2S) Downstream oxygen sensor (HO2S) wiring damaged or connected improperly *The engine coolant temperature sensor is not working properly *Damaged or leaking exhaust manifold / catalytic converter / muffler / exhaust pipe *Retarded spark timing *The oxygen sensors in front and behind the converter are reporting too similar of readings *Leaking fuel injector or high fuel pressure *Cylinder misfire *Oil contamination I know for sure my coolant temp sensor is not working but the electric fan turns on and off. Must be a separate temp switch!? I checked for an exhaust leak by tightening the bolts on the exhaust manifold and found a broken one on the driver side closest to the firewall. On the same side, I also noticed a small oil leak coming from a plugged port on the head just above the exhaust manifold flange. It is dripping right onto the flange. Looks like I found the Trifecta of problems....if Bank 1 is the Driverside. Any help would be appreciated |
| All times are GMT -5. The time now is 02:22 AM. |
