2000 Grand Marquis Transmission Problem?
I have a 2000 Grand Marquis and recently (about 2 months) The car runs just find and shifts as normal but when I get up to speed 60+ and I have to let off the gas for whatever reason, I Have to slow the car down to around 25mph before i can accelerate anymore.
Any Ideas? 114k Miles |
Grand Marquis Transmission Problems
The problem you described is most often caused by a faulty "Throttle Position Sensor".
At 114,000 miles, your sensor would normally wear out, and should be replaced. I purchased a brand-new Motorcraft T.P.S. at Amazon.com -- (great price, fast delivery). Very easy to install in just a few minutes -- no special tools required. I ordered and installed a Motorcraft "Idle Air Control Valve" at the same time. Now at 155,000 miles -- Idle speed and transmission shifting are as smooth as silk. |
Originally Posted by 95 MERC
(Post 21542)
At 114,000 miles, your sensor would normally wear out, and should be replaced. I purchased a brand-new Motorcraft T.P.S. at Amazon.com -- (great price, fast delivery). Very easy to install in just a few minutes -- no special tools required. I ordered and installed a Motorcraft "Idle Air Control Valve" at the same time. Now at 155,000 miles -- Idle speed and transmission shifting are as smooth as silk. Any Ideas? Thanks |
Beats me, man --
Good Luck !! |
