2002 Marquis.....Hesitation on Acceleration
Check the M.A.F. sensor. Probably needs cleaning & do it with M.A.F. cleaner in the spray can & low pressure shop air if you have it. Usually a dirty maf will hesitate when you first hit the gas pedal but as you let off the motor will get after it. Takes a tamper proof torx 20 IIRC. If it's never been messed with the screws will have pooky in the heads that will have to be dug out. If that's the case then it is most likely dirty. You can usually see fuzz on the elements inside the maf tip.
Tyler Warrick
Oct 25, 2012 12:34 AM
