2006 grand marquis door chime sounds while driving. generally at night at highway speed with lights, radio and cruise control on. it most noticeably happens when i put the directional light on and then the door chime sounds in an irregular way. i have also noticed that the radio and radio light may dim or go out. after i turn off directional light i sometimes have to turn the radio back on. i have a couple questions about this: <BR itxtvisited="1">1. does anybody know what this problem is ? <BR itxtvisited="1">2. dealer says if he can''t duplicate there''s nothing he can doand reporting it wont extend warranty coverage for this problem.<BR itxtvisited="1">don''t know if this is related but cowl was sealed twice due to water accumulation on passenger front and rear floor. that water affected rear door lock on passenger side. was told wiring harness had to be dried out second time cowl was sealed.<BR itxtvisited="1">thanks<! google_ad_section_end ><! / message ><! edit note > |
Don''t know what your problem is, can only tell you what mine was regarding the chime. The chime for "door/trunk ajar", "key-in-ignition and door open" and "lights-on and door-open" all sound the same on mine. I had the same issue and found out that the little plastic mount for the sensor (key-in-ignition/door open) in the steering wheel colom was broken. That allowed it to move around when driving, making contact, so it went off irregulary. Super-glued that back on, that did the trick. Greetings! |
| All times are GMT -5. The time now is 09:50 AM. |
