2007-2011 Air Deflectors
Does anyone have a photo of their 2007-2011 from under the engine bay or can tell me if the lower air deflector is located forward between the bumper and the radiator or is it further back? In other words if you remove the upper sight shield and look straight down will you see the air deflector or will you see the ground?
edit: I think I have this figured out. The lower deflector is simply a curved piece that bolts to the radiator support with three bolts and diverts air upwards into the condenser/radiator right? If you look under the car you can see the condenser, there is no piece that fits between the bumper & radiator. |
| All times are GMT -5. The time now is 06:25 AM. |
