-   -   2007 GM Only blow out defrost n floor (https://www.mercuryforum.com/forum/grand-marquis-14/2007-gm-only-blow-out-defrost-n-floor-10812/)
Power Oct 31, 2019 06:53 PM
2007 GM Ls only blows air out of the defrost and floor vents, also not blowing out heat when changing the temp. I thought about changing the O-rings in the VAC. Will that fix the "no heat" issue? I've had the car for 3yrs almost, great running vehicle.
