2009 MGM LS Ultimate Edition Cruise Control Not Working
Old Oct 17, 2021 | 10:48 AM
Gates's Avatar
Default 2009 MGM LS Ultimate Edition Cruise Control Not Working
10.17.2021 Cruise control stopped working last night. 09.20.2021 Changed out the brake light switch and now the brake lights work. I'm going out now and check under the dash to see if there are any loose connections. If not, I will drive to AutoZone for a scanner check and test if the new brake light switch failed. If any other 2009 MGM LS owners solved this type of problem would you please share your information.
Old Oct 17, 2021 | 11:05 AM
Default Dead Cruise Control
As always, check the Cruise Control FUSE first.
"Italian Lace" Wheels, Goodyear Comfortread Touring Tires - 98T. 32 Lbs. Front, 35 Lbs. Rear.
Old Oct 19, 2021 | 12:22 PM
Gates's Avatar
95 MERC Thank you for the recommendation.
MGM46
May 31, 2023 02:08 AM
usair
Aug 6, 2010 12:18 AM
PTLANDOLL
Jan 5, 2009 07:46 PM
jmbowman1
May 20, 2008 06:28 AM
quakboom
Jan 29, 2006 08:37 PM
