-   -   2009 MGM LS Ultimate Edition Cruise Control Not Working (https://www.mercuryforum.com/forum/grand-marquis-14/2009-mgm-ls-ultimate-edition-cruise-control-not-working-12537/)
Gates Oct 17, 2021 10:48 AM
10.17.2021 Cruise control stopped working last night. 09.20.2021 Changed out the brake light switch and now the brake lights work. I'm going out now and check under the dash to see if there are any loose connections. If not, I will drive to AutoZone for a scanner check and test if the new brake light switch failed. If any other 2009 MGM LS owners solved this type of problem would you please share your information.
95 MERC Oct 17, 2021 11:05 AM
Dead Cruise Control
As always, check the Cruise Control FUSE first.
https://cimg9.ibsrv.net/gimg/www.mer...4d24abc968.jpg
"Italian Lace" Wheels, Goodyear Comfortread Touring Tires - 98T. 32 Lbs. Front, 35 Lbs. Rear.
Gates Oct 19, 2021 12:22 PM
95 MERC Thank you for the recommendation.
