4.6 L Build up check it out
Old Jun 13, 2008 | 10:12 PM
jason sereiko's Avatar
picks of the415 h.p 4.6L 2vM. Basic buid on a budget. You will be amazed at what new heads will do on the 1998 MGM. I can post a build sheet if anyone is interested
[img]uploads/jasonsereiko/B7E_hrdp_0804_02_z+ford_4_6_engine+high_performanc e_engine_front_view.jpg[/img]
Old Jun 14, 2008 | 01:31 PM
<TABLE cellSpacing=3 cellPadding=2>
<T>
<TR>
<TD>1 ¡¯97 4.6L Crown Vic engine with 117K </TD>
<TD>$400.00</TD></TR>
<TR>
<TD>1 Edelbrock Victor Jr. carb intake manifold with MSD 6011 ignition module</TD>
<TD>$759.95</TD></TR>
<TR>
<TD>1 pair 4.6 PI Mustang heads and cams with unknown mileage</TD>
<TD>$250.00</TD></TR>
<TR>
<TD>1 pair PI valve covers</TD>
<TD>$15.00</TD></TR>
<TR>
<TD>1 Used Holley 650-cfm double-pumper</TD>
<TD>$150.00</TD></TR>
<TR>
<TD>8 Autolite 764 spark plugs</TD>
<TD>$12.72</TD></TR>
<TR>
<TD>1 oil filter </TD>
<TD>$3.99</TD></TR>
<TR>
<TD>5 quarts oil </TD>
<TD>$17.00</TD></TR>
<TR>
<TD>8 stock ¡¯99-and-later Ford ignition coils</TD>
<TD>$75.00 </TD></TR>
<TR>
<TD>1 BBK equal-length shorty header set</TD>
<TD>$299.99 </TD></TR>
<TR>
<TD>1 Fel-Pro valve-cover gasket set for PI 4.6</TD>
<TD>$36.99</TD></TR>
<TR>
<TD>1 Fel-Pro head gasket kit</TD>
<TD>$48.99</TD></TR>
<TR>
<TD>1 Fel-Pro 4.6 PI intake gasket set</TD>
<TD>$43.99 </TD></TR>
<TR>
<TD>1 Fel-Pro 4.6 PI exhaust gasket set</TD>
<TD>$11.99</TD></TR>
<TR>
<TD>1 set 4.6 head bolts</TD>
<TD>$69.00</TD></TR>
<TR>
<TD>1 11/2-inch expandable freeze plug</TD>
<TD>$2.99</TD></TR>
<TR>
<TD>1 5/8-inch hose cap and clamp</TD>
<TD>$1.99</TD></TR>
<TR>
<TD>Stage 1 Total</TD>
<TD>$2,199.59</TD></TR>
<TR>
<TD>HP: 288.7</TD>
<TD></TD></TR>
<TR>
<TD>LB-FT: 273.9</TD></TR></T></TABLE>
Old Jun 14, 2008 | 01:32 PM
<T>
<TR>
<TD>1 pair of jets for Holley carb </TD>
<TD>$5.00</TD></TR>
<TR>
<TD>Adjust timing</TD>
<TD></TD></TR>
<TR>
<TD>STAGE 2 TOTAL: </TD>
<TD>$5.00 </TD></TR>
<TR>
<TD>HP: 313.6 </TD>
<TD></TD></TR>
<TR>
<TD>LB-FT: 315.1 </TD>
<TD></TD></TR>
<TR>
<TD>Gain: +25.1 hp and +41.8 lb-ft</TD></TR></T></TABLE>
Old Jun 14, 2008 | 01:34 PM
<T>
<TR>
<TD>PRODUCT</TD>
<TD>PRICE</TD></TR>
<TR>
<TD>1 pair CNC-ported 4.6 PI heads with 46mm SI valves </TD>
<TD>$1,199.99 </TD></TR>
<TR>
<TD>STAGE 3 TOTAL:</TD>
<TR>
<TD>HP: 346.1 </TD>
<TD></TD></TR>
<TR>
<TD>LB-FT: 341.2 </TD>
<TD></TD></TR>
<TR>
<TD>Gain: +42.4 hp and +35.5 lb-ft</TD>
<TD></TD></TR></T></TABLE>
<T>
<TR>
<TD colSpan=3>HEAD FLOW CHART</TD></TR>
<TR>
<TD>INTAKE</TD>
<TD>BEFORE</TD>
<TD>AFTER</TD></TR>
<TR>
<TD>0.100</TD>
<TD>54</TD>
<TD>57</TD></TR>
<TR>
<TD>0.200</TD>
<TD>102</TD>
<TD>109</TD></TR>
<TR>
<TD>0.300</TD>
<TD>139</TD>
<TD>157</TD></TR>
<TR>
<TD>0.400</TD>
<TD>159</TD>
<TD>180</TD></TR>
<TR>
<TD>0.500</TD>
<TD>169</TD>
<TD>204</TD></TR>
<TR>
<TD>0.600</TD>
<TD>175</TD>
<TD>215</TD></TR>
<TR>
<TD>0.700</TD>
<TD>176</TD>
<TD>226</TD></TR></T></TABLE>
<T>
<TR>
<TD>EXHAUST</TD>
<TD>BEFORE</TD>
<TD>AFTER</TD></TR>
<TR>
<TD>0.100</TD>
<TD>55</TD>
<TD>57</TD></TR>
<TR>
<TD>0.200</TD>
<TD>91</TD>
<TD>98</TD></TR>
<TR>
<TD>0.300</TD>
<TD>121</TD>
<TD>136</TD></TR>
<TR>
<TD>0.400</TD>
<TD>137</TD>
<TD>172</TD></TR>
<TR>
<TD>0.500</TD>
<TD>142</TD>
<TD>187</TD></TR>
<TR>
<TD>0.600</TD>
<TD>150</TD>
<TD>194</TD></TR>
<TR>
<TD>0.700</TD>
<TD>153</TD>
<TD>209</TD></TR></T></TABLE>
<T>
<TR>
<TD colSpan=3>DYNO RESULTS: STAGE 3</TD></TR>
<TR>
<TD>RPM</TD>
<TD>LB-FT</TD>
<TD>HP</TD></TR>
<TR>
<TD>3,000</TD>
<TD>292.8</TD>
<TD>167.3</TD></TR>
<TR>
<TD>3,200</TD>
<TD>305.4</TD>
<TD>186.1</TD></TR>
<TR>
<TD>3,400</TD>
<TD>315.7</TD>
<TD>204.4</TD></TR>
<TR>
<TD>3,600</TD>
<TD>322</TD>
<TD>220.7</TD></TR>
<TR>
<TD>3,800</TD>
<TD>327.7</TD>
<TD>237.1</TD></TR>
<TR>
<TD>4,000</TD>
<TD>331.9</TD>
<TD>252.8</TD></TR>
<TR>
<TD>4,200</TD>
<TD>334.7</TD>
<TD>267.6</TD></TR>
<TR>
<TD>4,400</TD>
<TD>337.5</TD>
<TD>282.8</TD></TR>
<TR>
<TD>4,600</TD>
<TD>340.4</TD>
<TD>298.1</TD></TR>
<TR>
<TD>4,800</TD>
<TD>341.2</TD>
<TD>311.8</TD></TR>
<TR>
<TD>5,000</TD>
<TD>339.1</TD>
<TD>322.8</TD></TR>
<TR>
<TD>5,200</TD>
<TD>335.2</TD>
<TD>331.9</TD></TR>
<TR>
<TD>5,400</TD>
<TD>329.7</TD>
<TD>339</TD></TR>
<TR>
<TD>5,600</TD>
<TD>321.7</TD>
<TD>343</TD></TR>
<TR>
<TD>5,800</TD>
<TD>313.4</TD>
<TD>346.1</TD></TR>
<TR>
<TD>6,000</TD>
<TD>302.8</TD>
<TD>345.9</TD></TR></T></TABLE>
Old Jun 14, 2008 | 01:36 PM
<T>
<TR>
<TD>PRODUCT</TD>
<TD>PRICE</TD></TR>
<TR>
<TD>1 pair Comp Cams XE274H</TD>
<TD>$496.19</TD></TR>
<TR>
<TD>1 set Comp Cams valvesprings P/N 26113-16 </TD>
<TD>$166.87</TD></TR>
<TR>
<TD>1 set Comp Cams steel retainers P/N 792-16 </TD>
<TD>$50.40</TD></TR>
<TR>
<TD>STAGE 4 TOTAL: </TD>
<TD>$713.46 </TD></TR>
<TR>
<TD>HP: 380.4 </TD>
<TD></TD></TR>
<TR>
<TD>LB-FT: 345.4</TD>
<TD></TD></TR>
<TR>
<TD>Gain: +34.2 hp and + 9.6 lb-ft</TD></TR></T></TABLE>
Old Jun 14, 2008 | 01:40 PM
In the end, you can can make ggod budget power with used heads and cams from the mustang or go with aftermarket ones and ported heads for huge power.
This motor will be getting a 35-50 shot of nitros for off the line jumps. and after tunning it it will probably get the normal two stage 150 shot just for sfatey reasons and don''t want to blow it up.
Old Jun 14, 2008 | 01:43 PM
the toatl HP will be 415 with the first stage off the lineand 565 with the nitors through a two stage system total
Old Jun 18, 2008 | 08:25 PM
wow... just glad a 5.0 is a lil cheaper on the wallet for parts
Old Jun 18, 2008 | 08:40 PM
  #9
it is, but they don''t get 250K-300K in reliabliilty. Sometimes it costs to dare to be different
Old Jun 28, 2008 | 11:10 AM
  #10
if anyone wants a 5.0 L budget build sheet, dyno sheet for proof,let me know.
