I have a 84 Grand Marquis that is not starting. It is getting spark and
fuel but all it dose is turn over kind of slow. What it did is I was driving it and it just died and would not start again. |
Have you checked the engine and battery?
If it is a new battery, check the cables and make sure they are tight. a new battery can be defective, get it checked at the store like autozone.
check the volts on the battery with a volt meter. then check the volts at the starter. meters run about 10-50 bucks for cheap to good ones
check the fuel pressure with a gauge, it should be 30-35psi
I did everything mentioned above. One thing I did not mention it dose is it only gets spark at the coil when you first try and start it then no spark. Edited by: maxteca |
does this have eight coils ore one. Are the eight coils mounted on the valve covers or are they in packs of four?
I would take off the coils or coil and have the resistence checked at a parts store. Have them check the whole thing.i know autozone does it for free!
| All times are GMT -5. The time now is 03:32 AM. |
