I have a 1986 Grand Marquis with "Speed Density" Fuel Injection system. I want to upgrade it to an "Air Mass" Fuel Injection system. I want to do this for future modifications you cannot do with Speed Density. I have heard of folks swapping with a 90-96 Mustang systems, but I see that the wiring harnesses are totally different. The Engine Control Module (ECM) in a mustang is located inside the passenger’s kick panel and my ECM is located under the wiper motor in the engine compartment.
There is a 1991 Grand Marquis in a local junkyard that has the Air Mass system and I am thinking of using that due to the similar body style and wiring harness. The only draw back I see is it still runs the 14 lbs fuel injectors and not the 19 lbs like the mustangs do. My questions are for those that have already attempted a conversion: Did you go with a newer Grand Marquis or use a mustang instead? Was it a smooth conversion? Was it worth it? Would you do it again? What kind of problems did you have? Did performance/gas mileage improve? Any other comments/advice in converting to Air Mass would be appreciated. Tom < src="http://www.google-analytics.com/urchin.js" =text/> </> < =text/> _uacct = "UA-939292-45"; urchinTracker(); </> |
