-   -   93 grand marquis oil pan (https://www.mercuryforum.com/forum/grand-marquis-14/93-grand-marquis-oil-pan-1085/)
glenn Jun 15, 2007 03:40 PM
i just bought a 93 grand marquis and i need to replace the oil pan ,am i going to need to lift the engine to do this job!
92Mercury Jun 18, 2007 08:48 AM
Supposedly you do. However, I heard from others accomplishing the tasks by just raising the transmission a little bit.
See attached instructions/diagram:
[img]uploads/92Mercury/Oil_Pan_Bolts.gif[/img]
<A name=hd1-1-1-1>4.6L Engine</A>
If your vehicle is equipped with air conditioning, refer to General Information &amp; Maintenance for information regarding the implications of servicing your A/C system yourself. Only a MVAC-trained, EPA-certified, automotive technician should service the A/C system or its components.
    <TABLE cellSpacing=0 cellPadding=0 width=310>
    <T>
    <TR>
    <TD vAlign=top width=10 colSpan=2 height=10>http://www.autozone.com/images/upper_left.gif</TD>
    <TD vAlign=top width="100%" height=1>http://www.autozone.com/images/grey_line.gif</TD>
    <TD vAlign=top width=10 colSpan=2 height=10>http://www.autozone.com/images/upper_right.gif</TD></TR>
    <TR>
    <TD vAlign=top width=1 bgColor=#8c8c8c height="100%">http://www.autozone.com/images/clearpixel.gif</TD>
    <TD vAlign=top width=9>http://www.autozone.com/images/clearpixel.gif</TD>
    <TD vAlign=top align=middle width=290>
    <TABLE cellSpacing=0 cellPadding=0 width=290>
    <T>
    <TR>
    <TD align=middle bgColor=#ffcc00 height=15>CAUTION</TD></TR>
    <TR>
    <TD align=middle>http://www.autozone.com/images/clearpixel.gif</TD></TR>
    <TR>
    <TD>When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. </TD></TR></T></TABLE></TD>
    <TD width=9 height="100%">http://www.autozone.com/images/clearpixel.gif</TD>
    <TD width=1 bgColor=#8c8c8c height="100%">http://www.autozone.com/images/clearpixel.gif</TD></TR>
    <TR>
    <TD vAlign=bottom align=left width=10 colSpan=2 height=10>http://www.autozone.com/images/lower_left.gif</TD>
    <TD vAlign=bottom height=1>http://www.autozone.com/images/grey_line.gif</TD>
    <TD vAlign=bottom width=10 colSpan=2 height=10>http://www.autozone.com/images/lower_right.gif</TD></TR></T></TABLE>
      It may be necessary to loosen, but not remove, the 2 nuts on the rear transmission mount and with a jack, raise the transmission extension housing slightly to remove the pan.
