-   -   97 Marquis No Flashers, No Highbeams (https://www.mercuryforum.com/forum/grand-marquis-14/97-marquis-no-flashers-no-highbeams-1571/)
DKAudio Feb 14, 2008 12:18 PM
I have a 97 Grand Marquis with 126K. I bought the car used and have had it for 6 months. My high beams and hazards have never worked.
If I push down the button on the steering column for my hazards my blinkers stop working but I don't get any flashing.
If I mess with the lever for my high beams I can sometimes get them to blink but that is it. I'm assuming this is some kind of electrical problem, I am hoping this is common and a cheap fix.
Any ideas?
< =text/>
_uacct = "UA-939292-45";
urchinTracker();
87_Crown_Vic Feb 14, 2008 02:25 PM
sounds like you signal switch is going bad... also... check all fuses including under the hood
Edited by: 87_Crown_Vic
DKAudio Feb 14, 2008 04:03 PM
</>Checked all fuses already. How much is a signal switch, hard to install?
Also my headlights are super dim and I have silverstar ultras. I think I read to rub it with rubbing compound because the plastic yellows with time. I assume I do this on the outside of the unit? &lt; =text/&gt; _uacct = "UA-939292-45"; urchinTracker(); </>
< =text/>
urchinTracker();
</>Edited by: DKAudio
87_Crown_Vic Feb 14, 2008 04:07 PM
correct on cleaning of the exterior of lenses. signal switch isnt that hard... pull column cover off and get to the switch that way. i would disconnect the battery to avoid air bag issues.
DKAudio Feb 14, 2008 04:47 PM
sounds good, thanks
< =text/>
urchinTracker();
