99 Marquis Trans problem I think plz help
Hello,
1999 Mercury Grand Marquis LS 117,000 Miles My Problem While driving at a steady speed mostly low speeds 55 and below sometimes higher speeds. My trans feels like a jack hammer when I just slightly hold my foot on the gas pedal. Only way to make it stop is to let off the gas or give it more. Trans does shift fine though and when not acting like a jack hammer its a very smooth ride. Things I've Replaced Trans solenoid (both of them) Speed sensor fluid/filter Throttle position sensor Any ideas would be very much appreciated |
You were looking in the right area when you swapped the trans solenoids, but unfortunately that did not solve your issue.
It maybe scan tool time to see if your CVI is not getting pressures, etc. If your CVI shows high wear and your soleniod pressures are weak it maybe trans rebuild time. Sorry I could not be of more help here. Let us know who you make out, Bill |
| All times are GMT -5. The time now is 05:36 AM. |
