-   -   ABS Bleeding (https://www.mercuryforum.com/forum/grand-marquis-14/abs-bleeding-13034/)
jmrgn59 Mar 28, 2022 05:33 PM
ABS Bleeding
On a 2003 Grand Marquis I suspect I have air in or needs new ABS pump. How would I bleed one and what scan tool would I need? Thanks.....
raski Mar 29, 2022 04:54 AM
You didn't mention your symptom. Air will not enter the system unless it has been opened for a repair or the master cylinder ran dry because of a leak and air got in. However, you can flush out the old without a scan tool provided you don't let the master cylinder run dry and pump it.If you are having a spongy or low pedal with good linings, I would suspect a bypassing master cylinder than a faulty ABS module.
raski Apr 9, 2022 03:27 AM
Another post, hide and run, never to be heard from again till the next mishap.
95 MERC Apr 9, 2022 08:27 AM
Reminds me of the old song from WW2:
"There Ain't Nobody Here But Us Chickens!"
I guess we can't expect a lot of action on a forum for cars that haven't been made for over 10 years.
The juice ain't worth the squeeze.
